In theory, you can use all 26 bit of the STM32U MDF in the CIC stage. In practice, I recommend to stay < 25 bit to avoid artifacts and saturation.
_andreas
13 REPLIES 13
GwenoleB
Hello @Andreas Köpke​,
Can you provide more details about your observation, please?
In which condition you saw artefacts and saturation?
Thank you for your feedback,
Gwénolé
GwenoleB
Another point,
The MDF FIFO is set to 24 bits like CIC output can be extended to 26 bits. Then, to fit with FIFO it's mandatory to use the SCALE block.
In case you enabled the INT block after CIC + SCALE blocks, then there is no possibility to adjust the output size from 26 bits to 24 bits.
Best regards,
Gwénolé
_andreas
I use the B-U585I-IOT02A, modified VREF+ pin to be powered from internal VREFBUF 1.5V. Then I use the DAC1 to produce a sine wave, it gets quite close to the rails.
0693W00000UFRPIQA5.pngThe offset of the oscilloscope is around 35mV:
_andreas
Then I sample the signal with the ADC1 from PA4, also using 1.5V as reference voltage using a pretty plain setup (no oversampling etc) and feed it to the MDF.
When I use the CIC stage with SINC5 and a decimation of 4, this should result in 24bit wide internal results.
0693W00000UFRR4QAP.pngWhich gives a nice sine wave. However, if I use the same setup with decimation 5 then the internal results are 25.6bits wide - which is ok according to the datasheet - and I get this:
0693W00000UFRRsQAP.pngTo get this, I had to switch off the SATuration interrupt.
_andreas
I was not overly surprised, in my CIC simulation playing around with an "internal" width of 26, only 25bits were useful, before it saturated.
_andreas
There is a little room for improvement by using the correct offset.
_andreas
@Gwenole BROCHARD​ I've updated the thread.
GwenoleB
From your inputs, here are my comments:
  • Sinc5 - Dec4 the maximum amplitude read is 1.3e8 which can be represented on 27.9 bits. The maximum value on 24 bits is +/- 8.39e6
  • Sinc5 - Dec5, firstly there is an offset in the injected signal. It seems that with a full scale signal (14 bits) + offset a wrap-around occurs.
I will reproduce on my side but I don't expect an issue with the MDF. I come back with further analysis.
Thank you for sharing the details.
Best Regards,
Gwénolé
I'm referring to the Reference Manual
RM0456
Reference manual
STM32U575/585 Arm®-based 32-bit MCUs
March 2022, RM0456 Rev 3, page 1239
where it says:
with N = 5, D = 4 and DSin = 14 this results in
DScic = 24
and with N = 5, D = 5 and DSin = 14 this results in
DScic = 25.60964
Both values are within the recommendation DScic < 26bit.
