IAR configurations for stm32h7
‎2018-09-18 11:40 PM
‎2018-09-18 11:50 PM
Hello everybody!
I am trying to work with stm32h743ZI with IAR V7.70.1, While trying to configure IAR settings 'options' I can't find (at options > General otions) STM32H7 with the target processor devices from ST
Is there any package I need to install to allow me to choose the right chip I am using? or any other solution?
Thanks in Advance.
‎2018-09-19 3:41 AM
Hi @Moamen Ayman​ ,
The STM32H7 devices are not supported by IAR Embedded Workbench for ARM toolchain V7.70.1.
Please use version V7.80.4.
Supported Devices and EVAL boards
- STM32H743/753 devices
- STM32H743XI-EVAL
- STM32H743ZI Nucleo 144
Khouloud.
‎2018-09-19 4:39 AM
Thanks @Khouloud GARSI​ I will download this version V7.80.4 or higher.
‎2018-09-19 4:48 AM
@Khouloud GARSI​ I searched the supported devices in this version V7.80.4 but it's STM32H7 controllers are not supported!!
‎2018-09-24 10:18 AM
Hi @Moamen Ayman​ ,
You're right, the AR Embedded Workbench for ARM toolchain has started supporting STM32H7x3 devices starting from version V8.11.1 .
Sorry for any encountered inconvenience!
Khouloud.
‎2018-09-24 10:27 AM
Also you should be able to load example projects from the CubeH7 software trees.
‎2019-03-06 7:27 AM
Hello everybody,
I encountered a similar problem. But my situation is a little different. I have a license for "7.70" and I have to use this license.
Is there any method?
‎2019-03-06 7:44 AM
Does it support Cortex-M7? Find a close proxy and use that, and adapt the memory map.
STM32Cube_FW_H7_V1.3.0\Utilities\PC_Software\patch\EWARM\EWARM_v7_STM32H750xx_Support.zip
‎2019-03-06 7:49 AM
Can you select "Cortex-M7" as a Core?
