2020-11-20 12:46 AM
The STSW-IMG010 project recommends NUCLEO F401RE board but I have STM32NucleoG070.
Will the example work with STM32NucleoG070 . What will be the changes that i will have to do if i have to run the code in my board.
2020-11-20 01:38 AM
Yes, it will also work with the NUCLEO-G070RB, if you adapt the IOC, the board related stuff in the source code and insert the required drivers, e.g.
/Peter
2020-11-20 01:38 AM
/Peter
2020-11-20 01:59 AM
Thanks will try it and let you know
