2022-09-11 06:09 PM
2022-09-20 10:01 AM
Hi @豊和 金�? welcome to the Community ,
When you used the Hal UART with Interrupt mode, the callback functions are declared as weak functions in the driver, with no code to execute. This means that the user can declare the Tx / Rx callback again in the application and customize it to be informed in real-time about the process completion and to execute some application code. Contrary, when you used the Hal UART with polling mode, the data processing is handled internally in a loop. A timeout (expressed in ms) is used to prevent process hanging.
For more explanation, you can refer to this article.
Also, I advise you to take a look at this example.
Kaouthar
2022-09-20 10:01 AM
Kaouthar
