I want to convert ADC value to PWM value how to do it?
MM Ja.1
RomainR.
Hello @MM Ja.1 (Community Member)
Can you be more specific?
Do you want to know how to program the ADC and TIMER peripherals?
Which STM32 family are you working on?
Have you looked at the examples in the HAL/LL library, you should find projects that demonstrate the use of an ADC and others for TIMER PWM, you just have to merge the two functions in your own project.
Best regards,
Romain
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
