I have trouble getting ETM instruction trace out of stm32f411ve.
2019-09-06 8:47 PM
I've configured GPIO for trace , enabled trace in MCUDEBUG and coredebug registers and enabled ETM and started it.when I view the trace pins in a logic analyser.. there seems to be no activity on the trace pins. If you have example code for ETM trace using Stm32F4 please provide that.
Thanks in advance
DEBUG
STM32F4 Series
2019-09-06 9:48 PM
Keil had projects and debug configuration files for it ULINKPro and MCBSTM32F400
_WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000010); // RCC_AHB1ENR: IO port E clock enable
_WDWORD(0x40021000, 0x00002AA0); // GPIOE_MODER: PE2..PE6 = Alternate function mode
_WDWORD(0x40021008, 0x00003FF0); // GPIOE_OSPEEDR: PE2..PE6 = 100 MHz speed
_WDWORD(0x4002100C, 0x00000000); // GPIOE_PUPDR: PE2..PE6 = No Pull-up/Pull-down
_WDWORD(0x40021020, 0x00000000); // GPIOE_AFRL: PE2..PE6 = AF0
_WDWORD(0xE0042004, 0x000000E7); // DBGMCU_CR Enable 4-bit Trace
2019-09-06 11:16 PM
i don't want to use ULINKPRO. I just want to capture the trace pins in a logic analyser. How can I do that? Below is the code i execute after configuring gpio. But i observe no activity on trace pins. What do you think is the problem here?
DBGMCU->CR |= DBGMCU_CR_TRACE_IOEN; /* enable trace io */
DBGMCU->CR |= (3u<<DBGMCU_CR_TRACE_MODE_Pos); /* enable 4 pin data + 1 pin clock */
CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk; /* enable TPIU */
ETF_BASE_PTR->FCR |= 3u;
ETM_BASE_PTR->LAR = 0xC5ACCE55; /* unlock ETM registers */
ETM_BASE_PTR->CR = 0x00001D1Eu;
while(!((ETM_BASE_PTR->SR) & (1u<<1u)));
ETM_BASE_PTR->TRIGGER = 0x0000006Fu;
ETM_BASE_PTR->EEVR = 0x0000006Fu;
ETM_BASE_PTR->TECR1 = 0x00000001u;
ETM_BASE_PTR->CR = 0x0000191Eu;
while(((ETM_BASE_PTR->SR) & (1u<<1u)));
2019-09-07 7:46 AM
It was cited as a working example that could be reviewed and probed.
ARM might have a document for debugger writers. Segger might scripts.
I'll query one of my contacts.
2019-09-07 8:10 AM
In the debug configuration file, that keil provides for u link pro, which you mentioned, they do only GPIO configuration... I guess Trace / ETM configuration is done by the IDE itself via JTAG if trace is enabled? or you pasted only a part of the script?. It would be really helpful if you can provide some insights..
