I have tried changing the GPIO output speed and then toggled the output and monitored it on a scope. There is a slight increase in rise time with the speed set to 50MHz, but otherwise very little difference. Why is this?
Options
‎2018-09-18 8:19 AM
Options
‎2018-09-18 9:25 AM
Which mcu?
Try to load the output with significant capacitance, tens of pF. Also, switch on the compensation cell, if your mcu has one.
Options
‎2018-09-18 9:52 AM
What kind of load to you have on that pin? Is it connected to anything? Depending on the load you may not see any (or much) difference. For example, a pin with no connection or one driving a high-impedence/low capacitance load won't show much difference. A pin driving a low impedence and/or high capacitance load will show a big difference.
