2018-09-28 02:17 AM
Hi guys!
I have a problem with stm32f103, I want to check MCU Reset cause, I use RCC_GetFlagStatus is ok, after that i'll clear rcc flag but It's not working & MCU not working when user RCC_ClearFlag. If i remove RCC_ClearFlag function then MCU work normal but RCC Register Reset don't clear so i don't know cause MCU reset.
I try RCC -> CSR |=0x01000000 set RMVF to clear flag but it also not working
Can you help me, thank a lot!
2018-09-28 03:53 AM
I debug then see clear reset flag success but after that MCU not working if reset again or on/off power. remove funtion RCC_ClearFlag and program again turn off all power and turn on again mcu will working.
