I am using STM32G491REI6 Microcontroller. Can we connect Microcontroller ground to the earth to avoid EMI??
Champak Kundu
2 REPLIES 2
raptorhal2
Lead
MCU ground should be your MCU power supply ground, else EMI will be the least of your problems.
raptorhal2
Lead
If you describe the power source, packaging design and EMI source, you might get a better response.
