I am using MAT/TARGET I would like to know how use the SPI block thought simulink
MGian.1
I already used MAT/TARGET and it works pretty good. Now I have a problem with SPI I can't find enough information to build my block diagram correctly with SPI. In particular I don't understand which type of data require in Input and how can I use simulink to generate a data store that I can use to send data trough SPI.
Can anyone help me? may be with some example thanks
hendrikk
Use the byte pack block (embedded coder) or use matlab function block (Simulink / User-Defined Functions) like in the SPI example of the STM32Mat folder.
