I am using Keil IDE and during debugging in the call stack + locals window the variables I have defined are appearing as not in scope.
TGhau.2088
I am getting warnings that AccY, AccZ and Avg are not being used.
Pavel A.
Evangelist III
Usually the compiler is correct.
Try to disable optimization. Optimization removes unused code and variables.
As you see, lines 144, 145 are optimized out.
-- pa
Probably in a register in MCU and FPU. Look at the actual assembler generated and where it is holding the values.
Get rid of all the delays, and print values to a console. Shouldn't need to step this stuff.
