i am use a STM32H742xI/G mcu and i want to increase the buffer of the external flash memory how i do it?
Hmizr.1
The question is unclear.
You want to add a QSPI memory, or change the current one for a larger device?
You'd need to code a BSP for the chosen memory chip, and board level connectivity. The memory device should have a datasheet describing the functionality, commands and expectations.​
