I am receiving data from AD7768-4FMCZ but the Data is not synchronized how can synchronize the DATA ??
SA  V.1
@Javier Muñoz​ @Community member​
7 REPLIES 7
Is there an external signal you can use for synchronization, or is it embedded in the data (header/status).
Perhaps Analog Devices has some FAE's you can discuss use-cases with?
I am not using any External signal to synchronize.
Data(header/status are embedded ).
What is FAE's ??
Field Applications Engineer, someone designated to get design wins, support customer use cases.
The AD7768 is a part you've chosen, it's not a part I'm looking to learn how to use.
If information is embedded in the headers, process that to recover synchronization.
MM..1
Chief III
Show MCU, your receive code, speed , how you connect DRDY usw. Your question lacks all info
The OP​ has half a dozen related posts, rather than continuing the same theme/topic.
He/She keeps DMing me and i keep telling him/her to post the questions in the public forum.
Or to hire me as a consultant.
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
Javier1
Principal
@SA V.1​  it looks like youre new to this forum.
Tips:
-Condense all your inquiries into a single post, specially if they are closely related.
-Answer the questions and expand the information your giving us.
