HSE Failed to start
‎2016-02-08 1:01 AM
i have connected a external clock on stm32f4 microcontroller but the hse is failled to startup the application code (the internal clock works perfectly though.)- Mark as New
‎2016-02-08 1:52 AM
Dear emb_begin,
First deinit your RCC then Config RCC(HSE Enable). In HSE enable follow the following--1.Reset HSEON bit.2.Reset HSEBYP bit3.Enable HSE/*Please
mark helpfull
if this post helps you or solves your problem.*/
/**disclaimer**/
/* I am not a person from ST Technical Support Team. So please verify/test any support/suggestion at your end.*/
/* This post is only for general support purpose and free of any charge.If you need any personal support for your work please contact at
embeddeddesign.help@gmail.com
‎2016-02-08 5:30 AM
i have done it and it runs the application..
Now the usart output(send some string) on tera term is not working and i am getting a garbage values. The usart output works fine with the internal clock.- Mark as New
‎2016-02-08 8:36 AM
You should perhaps review the timeout period, and the design/characteristics of your circuit. Evaluate how long it takes to start over voltage/temperature.
For odd data output, make sure that HSE_VALUE reflects the speed of your chosen external clock.Up vote any posts that you find helpful, it shows what's working..
‎2016-02-11 5:17 AM
thank you,clive.
‎2016-02-11 5:58 AM
HSE_VALUE is a define, either passed in the compiler's command line via project settings, or within the stm32f4x_conf.h type file.
For an 8 MHz clock it needs to be 8000000, if you have a different crystal frequency it will need to reflect that. Your PLL settings also need to match your design, see system_stm32f4xx.c The HSE_VALUE is used in computing clocks related to the baud rates settings, so if it is wrong, all you serial data with be garbled.Up vote any posts that you find helpful, it shows what's working..
‎2017-04-02 5:43 AM
Hi.
Maybe it help you.
If you use STM32CubeMX it's bug of STM32Cube code generator. When you don't use HSI new code don't have full initialization RCC_OscInintStruct for HAL_RCC_OscConfig() in main.c of created project.
I put into stm32f4xx_hal_rcc.c at start of function HAL_RCC_OscConfig the following code:
__weak HAL_StatusTypeDef HAL_RCC_OscConfig(RCC_OscInitTypeDef *RCC_OscInitStruct)
{ if (RCC_OscInitStruct->HSIState != RCC_HSI_ON){RCC_OscInitStruct->HSIState = RCC_HSI_ON; RCC_OscInitStruct->HSICalibrationValue = 16;};
if (RCC_OscInitStruct->LSIState != RCC_LSI_ON) {RCC_OscInitStruct->LSIState = RCC_LSI_OFF;};
if ((RCC_OscInitStruct->LSEState != RCC_LSE_ON) ||\
(RCC_OscInitStruct->LSEState != RCC_LSE_OFF)||\ (RCC_OscInitStruct->LSEState != RCC_LSE_BYPASS)) {RCC_OscInitStruct->LSEState = RCC_LSE_OFF;};uint32_t tickstart = 0U;
/* Check the parameters */----------------------------------------------------------------------------------------------------------------------------------------
Thank you.
