How to use ST32MC0 for I2C communication over 2050 bytes?
‎2023-08-01 1:04 AM
I am using STM32C031C6 for I2C verification.
I tried to communicate 2050 bytes of data using the HAL driver.
However, it did not receive the correct data.
To be precise, the data at 512,1024,1344,1346,1538,18561 and 1858 bytes were different.
The settings are as follows.
hi2c1.Instance = I2C1;
hi2c1.Init.Timing = 0x0090194B;
hi2c1.Init.OwnAddress1 = 0x10;
hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
hi2c1.Init.OwnAddress2 = 0;
hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
Executed with the following description.
"HAL_I2C_Master_Receive(&hi2c1, dev_addr, i2c_read, 2050, 1000);"
Please let me know how I can receive 2050 bytes of data correctly.
STM32C0 Series
‎2023-08-02 7:19 PM
Hi @Foued_KH,
Problem solved.
The cause was my mistake in writing the program.
Thanks for your support.
‎2023-08-01 2:31 AM
Hello @kkazu ,
If you want to receive 2050 bytes of data, please flow this sequence : ( Figure 232. RM0490 )
Foued
‎2023-08-01 5:21 PM
Hi @KHALSI_Foued
‎2023-08-02 7:19 PM
Hi @Foued_KH,
Problem solved.
‎2023-08-04 6:51 AM
Why the hell are you attaching a HAL file, which is available for everyone anyway?
