how to use J-Link in Ac6 System Workbench for STM32 environment?
wjandsq
Posted on August 30, 2015 at 11:10
In Ac6 System Workbench for STM32 environment, how to use J-Link for debug?
#j-link-ac6 #ac6-new-board-define
wjandsq
Posted on December 22, 2016 at 08:00
11 REPLIES 11
Posted on August 31, 2015 at 13:51
Hi wjandsq,
Generally openocd supports J-Link, but it depends on the board you are using.
Try to follow these steps:
-Open debug Configurations, under Debugger view, script:
Tick Use local script
Browse configuration script and go to
..\STM32Cube_FW_F3_V1.2.0\Projects\board _name\Examples\..\..\SW4STM32\board_name/.custom.cfg
In .custom.cfg:
*change line 4 by source [find interface/jlink.cfg]
*comment transport select “hla_swd�
*change line 10 to  source [find target/stm32f3x.cfg] (for f3 family for instance)
Could you please also precise your board?
-Shahrzad-
wjandsq
Posted on September 13, 2015 at 05:29
Hi shahrzad!
 Thank your reply!
 In Ac6 System Workbench for STM32 environment,new board define have no jlink, my custom board use stm32f4xx.
1  # This is an ac6_f4_std board with a single STM32F407ZETx chip.
2  # Generated by System Workbench for STM32
3
4  source [find interface/jlink.cfg]
6  set WORKAREASIZE 0x20000
7  transport select ''hla_swd''
8
9
10 source [find target/stm32f4x.cfg]
11
12 # use hardware reset, connect under reset
13 reset_config srst_only srst_nogate
 fail to debug
Posted on September 14, 2015 at 17:31
May be the Ac6 / SW forum would be a better place to find support, scripts and templates for J-Link debugger support?
leogarberoglio
Posted on September 15, 2015 at 14:23
that forum is almost dead...
Posted on September 15, 2015 at 14:57
That doesn't reflect well on the user base then, does it...
Posted on September 15, 2015 at 16:07
Hi wjandsq,
Ensure that you have selected a board for your project, otherwise the debug session will not run.
0690X00000604sQQAQ.png -Shahrzad-
wjandsq
Posted on September 19, 2015 at 15:06
I will try again,Thanks!
Open OCDä¸�能直接æ�?¯æŒ�Jlink,需è¦�ä¿®æ�?¹Jlink驱动,宣布失败,ä¸�å†�å°�试了。
wjandsq
wjandsq
Posted on December 22, 2016 at 08:01
Ac6 use JLink Debug OK!   the modify is
${openstm32_compiler_path}\arm-none-eabi-gdb.exe
