how to stabilize ADC output
‎2022-09-12 1:59 AM
we are reading pH sensor by using nucleo 32L746RG.
even though both VDD and sensor value looks stable on tester like 3.3v+-0.1mv/ 2v+- 1mv, the adc value shows about 10% up/down around the true value.
the adc value seems to repeat increasing and decreasing in about few minutes.
could you please advise possible cause of the problem above?
followings are our adc setting;
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.ScanConvMode = ADC_SCAN_DISBLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc3) != HAL_OK)
Error_Handler();
/** Configure the ADC multi-mode
multi.Mode=ADC_MODE_INDEPENDENT;
if(HAL_ADCEX_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLETIME_640CYCLES_5;
sConfig.SingleDiff = ADC_SINGLE_ENDED;
sConfig.OffsetNumber = ADC_OFFSET_NONE;
sConfig.Offset = 0;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
ADC
STM32L4 series
‎2022-09-12 4:41 AM
did you measured the PH sensor signal output with an oscillocope? did you fing the same wavy behaviour?
How is your ground between the ph sensor and the stm32 connected?
Show us
‎2022-09-12 5:02 AM
Thank you for your message.
yes, we measured sensor voltage with occilloscope.
Sensor is ​insulated.
so the ground doesn't connected to stm32.
‎2022-09-12 5:18 AM
between the sensor and stm32, there are isolation-amplifier.
‎2022-09-14 2:37 AM
Great, did you noticed the same ondulations?
‎2022-09-14 2:38 AM
I bet you have a groundig issue, if you share the schematics maybe we could help you further
