how to resolve CAN transmit error in STM32L452RE-P ?
JLoli
i am getting error transmit error while using CAN in normal mode so if any work on that please let me know how to resolve
thank you in advanced
13 REPLIES 13
JLoli
yes i found example code for some different stm mcu and crossed checked code with that both are same only but dont know that code is right or not cause i did not checked that as i dont have that MCU with me .
and ya i can transmit frame with every second but after transmission it is checking that anyfifo is free or not at that time i am getting ERROR . for receiving side also first it should check that any receivefifo is empty or not than it will receives data but in that function i am stucking i tried that also
JLoli
ok i will try thank you
JLoli
ok let me try thank you
T J
Lead
how do you know you transmit ? do you have a scope ?
