How to implement USB DPM, prevent hard reset
‎2025-03-23 10:21 PM
I tried following STM32 AN5418 but the EvaluateSinkCapabilities method is not getting called. I added debug prints everywhere in the code and here is what I am receiving:
1. VBusInit (this always happens)
2. DPM notification 104 (Stack init)
3. Cable detection
4. Unimplemented SetDataInfo 8 (USBPD_CORE_EXTENDED_CAPA)
5. SetDataInfo 6 (USBPD_CORE_DATATYPE_RCV_REQ_PDO
- I haven't implemented anything in this, but I had it print out what it received and it looked good (e.g. 5V 3A 9V 3A 20V 5A etc.)
6. Notification: 30 (USBPD_NOTIFY_HARDRESET_RX)
7. Hard reset callback
8. Device turns off, turns on a few seconds later and goes through this same loop
What do I need to implement to get this working? Is this just because all of my methods are unimplemented besides EvaluateSinkCapabilities and one of the cases in GetDataInfo? At what point/do I call USBPD_DPM_RequestMessageRequest?
STM32G4 Series
UCPD
USB
‎2025-03-25 5:49 AM
Hi @Nv7
Would you describe your working environment? Would you attach your project?
USBPD_DPM_RequestMessageRequestfunction is used to send a power request to the source device based on the selected Source PDO and the prepared RDO. Check this example.
‎2025-03-26 8:40 PM
https://github.com/TektiteBiz/charge2b Here is the code. It appears that RequestMessageRequest is unimplemented, as well as everything else. I am not sure how to implement these.
Looking at the example it seems that it is unimplemented there too. (https://github.com/STMicroelectronics/STM32CubeG0/blob/fa3123ccb654f447d3738b86740fb869b2701ace/Projects/STM32G081B-EVAL/Applications/USB-PD/USB-PD_Consumer_1port/Src/usbpd_dpm_user.c#L535)
USBPD_StatusTypeDef USBPD_DPM_RequestMessageRequest(uint8_t PortNum, uint8_t IndexSrcPDO, uint16_t RequestedVoltage)
USBPD_StatusTypeDef _status = USBPD_ERROR;
/* USER CODE BEGIN USBPD_DPM_RequestMessageRequest */
/* To be adapted to call the PE function */
/* _status = USBPD_PE_Send_Request(PortNum, rdo.d32, pdo_object);*/
DPM_USER_DEBUG_TRACE(PortNum, "HELP: update USBPD_DPM_RequestMessageRequest");
/* USER CODE END USBPD_DPM_RequestMessageRequest */
DPM_USER_ERROR_TRACE(PortNum, _status, "REQUEST not accepted by the stack");
return _status;
‎2025-03-26 10:31 PM
I tried adding a request through USBPD_PE_Send_Request inside of SetDataInfo because that successfully receives the source capabilities, whereas the EvaluateSinkCapabilities function is never called (not sure why). The device still receives notification 30 - HARDRESET_RX and then gets power cycled.
Do you have any idea on what could be causing the hard reset message - perhaps a protocol violation I am unaware of? Do you know why EvaluateSinkCapabilities isn't getting called?
