janniscarstensmc
How to debug program from SRAM
  • June 3, 2013
  • 649 views
Posted on June 03, 2013 at 10:21
Edit: Forumsoftware doesn´t work on mobile devices
    Tesla DeLorean
    Guru
    June 3, 2013
    Posted on June 03, 2013 at 13:20
    Pretty much the same way you do for any other address range, you modify the linker and debugging scripts as required by the architecture and tools.
    janniscarstensmc
    Posted on June 03, 2013 at 22:23
    Hi
    Sorry, I thought I wrote a short text in my priveous post, but obviously I submitted it uncorrectly.
    I'm working with ARM Keil and uVision IDE, there I set  up the SRAM as the target location in the file options.
    Is that the correct method to do this?
    Another question: Then configuring the ST-Link, must I enter as Flash address the address of the SRAM or are some more settings required ?
    Regards Jannis
