How to create a 2D array of size array[10000][10000]
manoritesameer
Posted on April 03, 2014 at 19:42
hello,
      How to create a 2D array of size array[10000][10000]. I am getting the following error
          unable to allocate space for sections/blocks with a total estimated minimum size of 0x66d14 bytes in <[0x20000000-0x20020000]> (total uncommitted space  .
#stm32f
6 REPLIES 6
Posted on April 03, 2014 at 19:50
No kidding, the part you're using doesn't have 100MB of space to give you.
manoritesameer
Posted on April 03, 2014 at 22:38
Thanks Clive for the prompt reply.
One more Question how would I update the .DMA_BufferSize resistor as I update the PWM value by modifying the TIMx->CCRx resistor.
Thanks Again.
Posted on April 03, 2014 at 22:54
I don't really understand the question, you can DMA_DeInit()/DMA_Init() to reconfigure a DMA transfer.
Posted on April 03, 2014 at 23:34
''how would I update the .DMA_BufferSize resistor (sic) as I update the PWM value by modifying the TIMx->CCRx resistor (sic)''
I think you mean re
g
ist
e
r?
These are resistors:
http://electronicsclub.info/resistors.htm
manoritesameer
Posted on April 03, 2014 at 23:37
Sorry for the trouble, I figured that out.
Also one more thing I want to communicate to the terminal through USB, Do u have a sample code. I am using the STM32F4 discovery board.
Thanks again...
Posted on April 04, 2014 at 00:39
I did port the VCP example to the STM32F4-DISCO
https://drive.google.com/file/d/0B7OY5pub_GfIcTJvY0RLaUViVnM/edit?usp=sharing
