Olly Kao
Sep 16, 2020 8:52 AM UTC
how to cover previous HAL_UART_Transmit_IT with a newer one?
I'm trying to transmit a newer data while the previous transmit interrupt hasn't finished, I simply just call HAL_UART_Transmit_IT again and the result is the first called interrupt will finish its whole job and the second call do nothing, I know there're Abort function to stop previous transmit, but this is too slow, I need the newer data immediately cover the transmitting data. Any help???
Sep 16, 2020 1:32 PM UTC
Why is abort/restart too slow? It should do things immediately, minus a some clocks for all the HAL overhead.
You can't change the data mid-byte.
Tesla DeLorean
Guru
Sep 16, 2020 2:02 PM UTC
Change your buffering paradigm. The USART interrupts for each byte.
