How to connect and flash application to STM32F769I Disco via JTAG?
MdFayaz
Hi all, I need to flash SBSFU to STM32F769I - Disco via JTAG. While I try to connect to the board via JTAG, the following error shows up.
_legacyfs_online_stmicro_images_0693W00000bkdEgQAI.pngDo I have wrong configuration settings or is there any other problem?
MdFayaz
Thanks @Imen DAHMEN​, the shared document was useful. And I went through some more documents and came to know that STM32 F769I Discovery board does not have JTAG port (has only SWD)
3 REPLIES 3
Imen.D
Hello @MdFayaz​ ,
Check the cable. Check the pins/connectors according the AN4661 Getting started with STM32F7 Series MCU hardware development (Internal pull-up and pull-down on JTAG pins" section)
Imen
Imen
MdFayaz
The Workaround is to use the SWD port instead of JTAG port.
Imen
