how to change the frequency of gpio pins?
Ranjeet Singh
i am generating a pulse using gpio pins ,how i can change the frequency ?
7 REPLIES 7
Javier1
Principal
The frecuency of the pulses?
why dont you use a proper PWM timer
we dont need to firmware by ourselves, lets talk
Ranjeet Singh
how i can generate the pulse with pwm timer on time-10 us and off time 1 second
on time -10 micrsecond,off time -100 miliseconds
??? your first is 1Hz freq second is 10Hz explain what you need....
special PWMs you can create with master slave tim or DMA circular ...
0693W00000aH6F5QAK.gif@MM..1​ I believe he is a chatGPT bot using a human's forum.
Machines are asking the questions now
HOUUOU SKYNET
Communicate which STM32 you are talking about here. What frequency?
Does it have any 32-bit TIM ?
>>on time -10 microseconds, off time -100 milliseconds
9.9990000999900009999 Hz ??
