2016-06-21 07:28 AM
I'm using STM32L053R8 for my data logger project. I would like to see lutra low powers. My custom board which is running by MSI clock is consuming 2.2mA. I'm running with only MSI clock i.e.2MHZ. In the attached image you can see my clock configuration. Are there any other configurations to do?What are the other things to be concentrated to reduce the current consumption?.Thank you.2016-06-21 08:43 AM
What you are connecting to externally? The components, and current paths you are creating.
