2010-10-10 10:45 PM
How it is possible to have the PA10 output on STM3210E-EVAL board?
2011-05-17 5:10 AM
it is not a problem if it is connected with R1-Out PIN. there is a resistor R36 in between so your logic level wont be disturbed. you can see your output at connector-CN10 (PIN-8).
hope it helps. Regards
2011-05-17 5:10 AM
But the R36 is 0-Ohm. Anyway, thanks for your help. At least it let me know I didn't miss anything. The ST should remind user in their readme file to remove this resistor.
Best Regards,
