2019-10-22 05:32 AM
I am trying to understand build boot loader with flasher loader demonstrator application. I came across this problem i.e., I could not able to select port in that application. I am using windows 10,
Any inputs are much appreciated!!
2019-10-24 03:03 AM
Check the connexion with your cable or change it.
Otherwhise, try to use STM32CubeProgrammer tool for programming STM32 products..
Best Regards,
Imen
2019-10-24 04:12 AM
There isn't a standard method to query available ports as I recall, one can enumerate some registry values. Perhaps Win10 altered things or there is something different about theses ports.
Try using STM32 Cube Programmer in UART mode
