How can ı use the FPU (Floating Point Unit) in STM32F407?
msergencatal
Hİ. I have been working on motor control applications. There are PID, FOC and SVPWM blocks that have contain functions like sin(), cos(), clarke(), park() etc. I used CMSIS DSP library called "arm_mat.h". My microprocessor is STM32F407 M4. I can control the motor but i want to reduce my execution times. I use STM32CubeIDE. How can ı enable fpu of STM32F407? Maybe it enable but i dont know how can i view fpu enable or disable in STM32CubeIDE?
The CM4F FPU doesn't support transcendental math functions, or doubles. It only supports relatively simple float (32-bit) operations. Most anything else is in the C compilers math libraries, likely using the FPU to the extent that is practicable.
Typically one selects the use of the FPU on the tool side (check your manual/user guide), GNU has several command line options for hard/soft FP ABI register usage.
On the MCU side, defines passed by the tools usually have code in SystemInit(), or earlier, enable the FPU CoProcessor.
Not my tools, but sure this question has been asked/answered several dozen times, search the forum/net for exact details, screenshots, etc.
msergencatal
Thank you .
