Hi everyone, I am fairly new to ST and I'm working on a project where i need 8 phase shifted pwm signals(each phase shifted by 45 degrees and same duty cycle)
i was thinking if there is a way i could generate 4 timers phase shifted by 90 degrees wrt each other so that i could use them to generate 2 pwm signals (on each timer using asymmetric mode) . can this be done? if not, is there any other way i could do it?
