2017-01-19 4:20 AM
I have this SMD component that I cannot identify:Package size: SMCMarking from top:<STMicroelectronics logo> (e3) GFBR GP 611I have no idea what this can be, and by the way, is there any place or list where one can search by STMicroelectronics markings?Solved! Go to Solution.
2017-01-19 6:27 AM
2017-01-19 5:29 AM
Hi
kogowski.sylwester
I have moved your post to the
where someone should be able to assist you.Thanks
2017-01-19 5:54 AM
Hi
kogowski.sylwester
,Other than ST logo, is there any information about the ST product used on your SMD component?
For example: STM..
Could you provide more details about this component (or at least its picture).Khouloud.
2017-01-19 6:27 AM
2017-01-19 6:35 AM
Thank You! Waclawek.Jan
How did you found it out? Is there any database or something?2017-01-19 9:16 AM
There are several such databases around on the net. I use caxapa.ru/codebook , with some little familiarity with Russian you can also add codes yourself (might require login).
