Hello Guys, I have got problem with debugging. While running debugging the error comes up: 120/5000 120/5000 Error message from debugger back end: localhost: 61234: The system tried to join a drive to a directory on a joined drive
MOrsz.1
I am using nucleo f401-re and I am a beginner. I have run couple of simple programs, and till today it works fine. Does anyone had similiar problem?
Thanks in advance
1 REPLY 1
Might be one of those odd things that is solved by a reboot. What is your environment? OS and IDE
