hard fault handler
Options
‎2013-08-03 4:47 PM
Posted on August 04, 2013 at 01:47
hi,
i am working on stm32f407. i am experiencing hard fault handler.start:{}
timer();while(!one_second_timer){ /*my code*/}goto start;and the code for timer isvoid timer(void)
{ uint16_t PrescalerValue = 0; TIM_Cmd(TIM3, DISABLE); one_sec_timer_interrupt = 0; NVIC_InitTypeDef NVIC_InitStructure; /* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* Enable the TIM3 gloabal Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 65535; TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); /* Prescaler configuration */ TIM_PrescalerConfig(TIM3, PrescalerValue, TIM_PSCReloadMode_Immediate); /* Output Compare Timing Mode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR1_Val; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM3, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Disable); /* Output Compare Timing Mode configuration: Channel2 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR2_Val; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC2Init(TIM3, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable); /* Output Compare Timing Mode configuration: Channel3 */ TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = CCR3_Val; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC3Init(TIM3, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Disable); TIM_ITConfig(TIM3, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 ,ENABLE); TIM_Cmd(TIM3, ENABLE);}
when i run this code for 20 minutes or more this controller hangs in hard fault handler. there is something wrong in re initializing all the timer code.1.) how can i reinitialize timer when one second timer interrupt expires? 2.) what is the reason for controller to go in hard fault handler (after 20 minutes)?thank you
3 REPLIES 3
Options
‎2013-08-03 7:33 PM
Posted on August 04, 2013 at 04:33
Problem likely with code not presented. Pity this is not a free standing example.
What's the interrupt code doing?What are you doing with CCRx registers?How's the 1 second thing function right now?The TIM could be set up to repeatedly interrupt on a second period, not sure why you even need to reset/reconfigure it to achieve that.What instruction is hard faulting? And what are the registers at that point?Are you violating some memory buffer?
Options
‎2013-11-20 11:00 PM
Posted on November 21, 2013 at 08:00
hello,have solved this problem?
Options
‎2013-11-21 6:50 AM
Posted on November 21, 2013 at 15:50
Does it matter? Hard Faults occur for many reasons, and you usually start by examining the processor state (registers, instruction) at the fault to diagnose why you have a specific problem. I've written dozens of posts on fixing Hard Faults.
