handling function parameters in assembly
lowpowermcu
Posted on October 20, 2010 at 22:57
2 REPLIES 2
Posted on May 17, 2011 at 14:12
First the first 4 parameters use ARM registers, they will be R0, R1, R2, R3, others will be pushed on the stack, local variables can either be in registers or relative to the stack frame. A 32-bit return value will be returned in R0. Look at the code generated by the compiler to get some worked examples.
You want to review the
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.subset.swdev.abi/index.html
and specifically the
http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042d/IHI0042D_aapcs.pdf
http://www.codesourcery.com/sgpp/lite/arm/portal/kbentry32
lowpowermcu
Thanks clive1
