HAL I2C Mem Read no longer working
isaacseeto
I have been using Mem Read and Write for my project involving STM32 and ST25DV64K. These functions have been working for me previously but now they return HAL ERROR. I used to encounter this when I was inputting the wrong address but I have since corrected that. I have attached my current project and previously working project.
1. What does HAL ERROR actually indicate?
2. Why might these functions no longer work?
Thanks.
isaacseeto
Hi, I believe I fried the circuit because I soldered a new one and it functions correctly.
Thanks for the suggestions.
3 REPLIES 3
Bob S
Principal
You have the HAL source code.  Use your debugger and see where in the HAL functions the error comes from.
Karl Yamashita
Principal
Did you check with an oscilloscope to be sure you have data activity?
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
isaacseeto
