slope.1
HAL_GetTick() always return 0 when i use UART
  • August 22, 2022
  • 3 replies
  • 2143 views
Hi, I work with STM32L562VET6Q, and when i try to comunicate with uart HAL_GetTick() fuction doesn't work because always return 0, but if i don't use uart work perfectly, What could it be due to?
I try to change prioritys in NVIC interrput table but still does not work.
Javier1
Principal
August 22, 2022
Are you using UART in interrupt mode?
Where are you placing those HAL_GetTick()?
also, quick google
hit me up in https://www.linkedin.com/in/javiermuñoz/
slope.1
slope.1Author
Yes, it is in interrupt mode, but I have tried to not use interrupt mode and uwTick is always 0 too.
it's in main.c
Tesla DeLorean
Guru
August 24, 2022
Is SysTick running? What's the Handler calling.
You call HAL_Init() before using the USART?​
