GNU LD Linker script for STM32F411
arnaud239955
Posted on August 26, 2015 at 22:30
Hello All,
I haven't found any linker script for ld / STM32F411 in the Cube package.
Can you advice me on which script to use ? I found old versions on the Internet generally not compatible (libopencm3 for instance) with the ST provided startup script.
Any advice / clue will be appreciated.
Thanks a lot
Zirco
3 REPLIES 3
thomfischer
Posted on August 27, 2015 at 00:13
create a project with CubeMx for Toolchain SW4STM32,
it generates a linker scrip in the folder <CubeProject>/SW4STM32/template Configuration
Amel NASRI
Posted on August 27, 2015 at 11:11
Hi Zirconium,
There are ld scripts for STM32F411RE under
-  STM32Cube_FW_F4_V1.7.0\Projects\STM32F411RE-Nucleo\Templates\TrueSTUDIO\STM32F4xx-Nucleo or
- STM32Cube_FW_F4_V1.7.0\Projects\STM32F411RE-Nucleo\Templates\SW4STM32\STM32F4xx-Nucleo
besides to the ones under projects folders.
-Mayla-
arnaud239955
Posted on August 27, 2015 at 17:43
Mayla, Thomas.004,  thank you very much.
Zirco
