getting internal RTC time always 00:00:00 (I am using STM32F446RE nucleo board )
JPanc.1
0690X00000BxBKOQA3.jpgI am using STM32F446RE Nucleo Board and want to read internal RTC timing.
But I am unable to get the time getting 00:00:00
Here I shared my core
Clock Setting: LSE : 32768Hz
System Clock: HSI : 84MHz
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  MX_USART2_UART_Init();
  MX_SPI2_Init();
  MX_FATFS_Init();
  MX_RTC_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  uint32_t prevTick = 0;
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
	  if((uint32_t)HAL_GetTick() - prevTick >= 2000)
		  if(read_truck_no(buffer))
			  send_uart(buffer);
			  send_uart("\n");
			  bufclear();
		  if(get_time(tTime))
		  sprintf(buffer,"TIME: %02d:%02d:%02d %d\n",tTime.Hours,tTime.Minutes,tTime.Seconds,HAL_RTC_GetState(&hrtc));
		  send_uart(buffer);
		  bufclear();
		  else
			  send_uart("RTC ERROR\n");
			  bufclear();
		  prevTick = HAL_GetTick();
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
bool set_time(RTC_TimeTypeDef sTime)
	sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
	sTime.StoreOperation = RTC_STOREOPERATION_RESET;
	if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) != HAL_OK)
		Error_Handler();
		return false;
	else return true;
bool get_time(RTC_TimeTypeDef gTime)
	if (HAL_RTC_SetTime(&hrtc, &gTime, RTC_FORMAT_BIN) != HAL_OK)
		Error_Handler();
		return false;
	else
		HAL_RTCEx_BKUPWrite(&hrtc, RTC_BKP_DR1, 0x32F2);
		return true;
bool set_date(RTC_DateTypeDef sDate)
	  sDate.WeekDay = RTC_WEEKDAY_FRIDAY;
	  sDate.Month = RTC_MONTH_JANUARY;
	  sDate.Date = 0x31;
	  sDate.Year = 0x20;
	  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) != HAL_OK)
	    Error_Handler();
		return false;
	  else return true;
bool get_date(RTC_DateTypeDef gDate)
	  sDate.Date = 0x31;
	  sDate.Year = 0x20;
	  if (HAL_RTC_GetDate(&hrtc, &gDate, RTC_FORMAT_BIN) != HAL_OK)
	    Error_Handler();
	    return false;
	  else
	  return true;
bool set_alarm(RTC_AlarmTypeDef sAlarm)
	  sAlarm.AlarmTime.Hours = 0x0;
	  sAlarm.AlarmTime.Minutes = 0x0;
	  sAlarm.AlarmTime.Seconds = 0x0;
	  sAlarm.AlarmTime.SubSeconds = 0x0;
	  sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
	  sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET;
	  sAlarm.AlarmMask = RTC_ALARMMASK_NONE;
	  sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL;
	  sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
	  sAlarm.AlarmDateWeekDay = 0x31;
	  sAlarm.Alarm = RTC_ALARM_A;
	  if (HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BIN) != HAL_OK)
	    Error_Handler();
	    return false;
	  else return true;
  * @retval None
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 84;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
    Error_Handler();
  * @brief RTC Initialization Function
  * @param None
  * @retval None
static void MX_RTC_Init(void)
  /* USER CODE BEGIN RTC_Init 0 */
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  RTC_AlarmTypeDef sAlarm = {0};
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
  /* USER CODE END Check_RTC_BKUP */
  /** Initialize RTC and set the Time and Date
  sTime.Hours = 0x18;
  sTime.Minutes = 0x45;
  sTime.Seconds = 0x0;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  sDate.WeekDay = RTC_WEEKDAY_THURSDAY;
  sDate.Date = 0x30;
  sDate.Year = 0x0;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /** Enable the Alarm A
  if (HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RTC_Init 2 */
  /* USER CODE END RTC_Init 2 */
void send_uart(char* string)
	uint16_t len = strlen(string);
	HAL_UART_Transmit(&huart2,(uint8_t *)string,len,2000);
int bufsize(char* buf)
	int i=0;
	while(*buf++ != '\0')i++;
	return i;
void bufclear(void)
	for(int i=0;i<1024;i++)
		buffer[i] = '\0';
1 REPLY 1
SStor
Senior
You should use HAL_RTC_GetTime() in your function get_time().
