parisa
generate pulse wave with stm32f10x and cmsis library
Posted on December 23, 2016 at 19:30
Hello
I'm supposed to generate pulse train with stm32f10x and cmsis library.
TIM_TimeBaseInitTypeDef TIMST;
TIMST.TIM_Prescaler=72;
TIMST.TIM_Period=1000;
TIMST.TIM_ClockDivision=TIM_CKD_DIV1;
TIMST.TIM_CounterMode=    TIM_CounterMode_Up ;
TIM_TimeBaseInit(TIM2, &TIMST);
         TIM_OCInitTypeDef TIMCRC;
        TIMCRC.TIM_OCMode=TIM_OCMode_Toggle;
        TIMCRC.TIM_OCIdleState=TIM_OCIdleState_Reset;
        TIMCRC.TIM_OCNIdleState=TIM_OCNPolarity_Low;
        TIMCRC.TIM_OCPolarity=TIM_OCPolarity_High;
        TIMCRC.TIM_OCNPolarity=TIM_OCPolarity_Low;
        TIMCRC.TIM_OutputNState=TIM_OutputNState_Disable;
        TIMCRC.TIM_OutputState=TIM_OutputNState_Enable;
        TIMCRC.TIM_Pulse=
But I don't know how I can define Pulse variable value for specific output frequency.(Is this code correct? or I did some mistake? )
#stm32f10x #timer
Amel NASRI
Posted on December 26, 2016 at 17:46
Hi
Mohamadi.Parisa
Please precise what do you expect exactly as result?
Did you tried this code and it doesn't match what you need?
I recommend you to refer to theGeneral-purpose timer cookbook (
http://www.st.com/content/ccc/resource/technical/document/application_note/group0/91/01/84/3f/7c/67/41/3f/DM00236305/files/DM00236pdf/jcr:content/translations/en.DM00236pdf
) : it explains various use cases related to timers and can be helpful for you to implement your own case.
-Amel-
To give better visibility on the answered topics, please click on "Best Answer" on the reply which solved your issue or answered your question.
parisa
parisaAuthor
Posted on December 26, 2016 at 18:14
Thanks for your response.
Actually I want to create a square pulse (frequency <100khz) with Stm32f10x and timer output compare mode.I have seen different codes that they use PWM mode but I want to learn how can work in output compare mode with timers?
So I need to know how can I define Prescaler, Periode and Pulse variables for an specific output frequency? and where can I find simple code in output compare mode?
I haven't read time cookbook yet but maybe I will find my answer.
