Pulse Width Modulation in stm32f10x
parisa
Posted on December 26, 2016 at 12:02
Hello
Here is my
function that doesn't work properly.what is my mistake?
Input Freq:72Mhz
Chip: f107
output pin:PA.0
TIM_TimeBaseInitTypeDef TStructure;
TIM_OCInitTypeDef OCStructure;
GPIO_InitTypeDef GPStruc;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
TStructure.TIM_Prescaler=7199;
TStructure.TIM_CounterMode=TIM_CounterMode_Up;
TStructure.TIM_Period=9;
TStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TStructure.TIM_RepetitionCounter=0;
TIM_TimeBaseInit(TIM5, &TStructure);
TIM_Cmd(TIM5, ENABLE);
OCStructure.TIM_OCMode=TIM_OCMode_PWM2;
OCStructure.TIM_OutputState=TIM_OutputState_Enable;
OCStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
OCStructure.TIM_Pulse=3599;
TIM_OC1Init(TIM5, &OCStructure);
TIM_OC1PreloadConfig(TIM5, TIM_OCPreload_Enable);
GPStructure.GPIO_Mode=GPIO_Mode_AF_PP ;
GPStructure.GPIO_Speed=GPIO_Speed_2MHz;
GPStructure.GPIO_Pin=GPIO_Pin_0;
GP_Init(GPIOA,&GPStructure);
Khouloud GARSI
Posted on December 26, 2016 at 15:39
Hello
Mohamadi.Parisa
I advise you to rearrange your code.
- configure the GPIO
- configure the TIMER
- Then enable the TIMER
Note: This condition should be respected: TIM_Period > TIM_Pulse
I think you are confusing between the prescaler and the period values.
There is a lot of examples using
https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef1.html
or
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-libraries/stsw-stm32html
. They will help you to generate the PWM pulses correctly.
If this solves your issue, please click on correct
Khouloud
Khouloud GARSI
Hello
Mohamadi.Parisa
or
Khouloud
