2022-06-15 12:21 AM
hello everyone, I have a small mistake when I want to make something like the photo, it give me error what is the problem, If anyone help me, It is very good for me, thanks.
2022-06-15 3:50 AM
So what error, exactly, does it give you?
"what is the problem?"
The error message will describe the problem - so read it carefully.
It may help to refer to a C textbook or other reference if you're unsure about terminology, and/or what the C language does allow...
https://blog.antronics.co.uk/2011/08/08/so-youre-thinking-of-starting-with-c/
If you're still stuck, please copy & paste the full text of the error from the 'Console' output view.
BTW: how to properly post source code:
2022-06-15 3:50 AM
2022-06-15 3:57 AM
thank you I have solved it you are right thank you also for the link
2022-06-15 4:37 AM
@bünyamin terzi You're welcome.
Now please mark the solution:
