FreeRTOS STM32H743ZI FPU Assembler Error
2023-12-05 08:39 PM
Hi there,
I’m trying to compile a project using the STM32H743ZI2 Nucleo board with STM32CUBE Framework with FreeRTOS with PlatformIO.
The project can be found here:
Zafeer_FreeRTOSFromGroundUp/PlatformIO/17_WorkingWithQueueSets at main · ZafeerAbbasi/Zafeer_FreeRTOSFromGroundUp (github.com)
But basically, I’m using an extra script to add flags:
Import( “env” )
env.Append(CCFLAGS=flags, LINKFLAGS=flags, ASFLAGS=flags)
However I keep getting the following errors:
…\Local\Temp\ccTwSuW0.s: Assembler messages:
…\Local\Temp\ccTwSuW0.s:330: Error: selected processor does not support vstmdbeq r0!,{s16-s31}' in Thumb mode ...\Local\Temp\ccTwSuW0.s:332: Error: instruction not allowed in IT block -- stmdb r0!,{r4-r11,r14}’
…\Local\Temp\ccTwSuW0.s:352: Error: selected processor does not support vldmiaeq r0!,{s16-s31}' in Thumb mode ...\Local\Temp\ccTwSuW0.s:354: Error: instruction not allowed in IT block -- msr psp,r0’
*** [.pio\build\nucleo_h743zi\libe54\Source\portable\GCC\ARM_CM4F\port.o] Error 1
The exact instructions can be found in port.c of FreeRTOS Kernel:
I’m not too experienced but any help would be greatly appreciated!
- Labels:
STM32H7 Series
2023-12-06 02:47 AM
The solution was based on PlatformIO platform.ini file, basically instead of:
and that did the trick!
( Also I used the CM7 Port instead of the CM4 port, S/O to @RomainR. for pointing that out!
2023-12-06 12:04 AM
Hello @rockybalboa__
I'm not familliar with PlateformIO IDE, but in errors you get, it seems you are using port.c of FreeRTOS Kernel for CM4. As STM32H7 is a CM7, you should use adequate FreeRTOS port.c for CM7.
Regards,
Romain,
2023-12-06 02:45 AM
Thank you for pointing that out, it really did help!
2023-12-06 02:47 AM
2023-12-06 02:55 AM
Thank you @rockybalboa__
Does it mean "pre:add_hardfloat.py" is a typo ?
Regards.
Romain,
