Freertos low Power Run mode
Hi guys,
I use stm32L4 and freertos, I try to make low power run mode in my project. Normally my mcu works 60Mhz but I want to reduce clock as much as possible in low power run mode like 1Mhz and I want to use freertos in low power run mode. I change clock configuration before low power run mode but in low power run mode freetos osDelay time change.
I need and example application for how to use low power run mode with freertos.
