float argument inside function stopping the infinite loop. screen sorts and file are given below. Edit: mcu I'm using is stm32f411re .
GMond.1
0693W00000JMx5tQAD.pngif I give argument like above picture infinity loop stops working
0693W00000JMx6wQAD.pngbut if I give the number num inside function the instead of giving argument then its working fine.
If I give int instead of double as the datatype of argument then also it's working.
Please help
5 REPLIES 5
Nikita91
Lead II
What MCU ?
Does it provide float or double ?
How do you configure the compiler: software or hardware float libraries?
Use the debugger to see where the code hangs
Please format your code correctly, it is hard to read...
Oh, sorry, stm32f411re is the microcontroller. I don't know how to configure compiler. It has the default setting. Double is working if i give the value inside the function. When I'm debugging and running the code the code runs successfully but infinity loop stops.
So where exactly does it end up if the loop stops? If you halt in the debugger where is it?
In the Hard Fault routine? Does that output any useful data so you could determine if it got there?
Is the FPU enabled?
Have you reviewed the code generated by the compiler?
S.Ma
Principal
Try to increase the stack size
Right click on the project name / Properties / C/C++ Build / Settings
