Flashing multiple microcontroller at a time
VChau
Hi All,
I want for flash multiple microcontroller at a same time,
kindly suggest any debugger/flash or any tool to achieve this
Georgy Moshkin
Senior II
Maybe using ST Link flash utility with USB hub. Find out their IDs and make a CMD file which runs multiple instances of ST Link utility in separate windows with different "ID=<id>" command line options.
Check my STM32 Bootloader - flash your STM32 with AES-encrypted binaries right from web browser!
Peter BENSCH
In addition to the possibility of using the USB hub suggested by @Georgy Moshkin​, you are probably looking for a so-called gang programmer. We list some on our partner website, e.g .:
/Peter
