Flash Loader Demonstrator Crash / AN3155
‎2010-04-20 12:58 AM
‎2011-05-17 4:47 AM
After compiling the FlashLoaderDemonstrator myself and debugging it, I found the cause of the crash. The parameter -i seems to be required but it is not checked in the app.
Nevertheless, I am still unable to upload images from my device or download them:>STMFlashLoader.exe -p --pn 2 -i STM32_High-density_512K -u --fn tmp.hex UPLOADING ... Uploading page 0 @0x 8000000 size 2.00(KB) [KO] Press any key to continue ...- Mark as New
‎2011-05-17 4:47 AM
This syntax (ie -c not -p) worked with V2.0.0
STMFlashLoader -c --pn 2 -i STM32_High-density_512K -d --fn DOWNLOAD.HEX You are correct about -i, if you don't specify it the app faults on a NULL vector. -CliveUp vote any posts that you find helpful, it shows what's working..
‎2011-05-17 4:47 AM
After some further investigation I canceled the FlashLoaderDemonstrator project and started to implement my own bootloader based on AN3155 because there are more cons than pros with the ST FlashLoaderDemonstrator sample app.
‎2011-05-17 4:48 AM
Came to the same conclusion, the protocol is pretty simple. If you only have to support one device and need a custom user interface for factory test/program starting from scratch would be easier than modifying the example code. -Clive
‎2011-05-17 4:48 AM
Actually I am struggling with the checksum. AN3155 mentions a XOR checksum, but it seems like a NXOR checksum to me (i.e. command and complement). For some cases, the checksum is correct, but the download of data to the device fails with a NACK after sending the datalength+data+checksum.
Do you know how the ''checksum'' is exactly calculated and if the datalength (when downloading) is involved in the checksum? Carsten- Mark as New
‎2011-05-17 4:48 AM
The internal bootloader does it like this:
data size=1 byte => checksum = data[0] ^ 0xFF; data size>1 byte => checksum = data[0] ^ data[1]^...^data[size-1] I suppose, that the other bootloader does it the same way.- Mark as New
‎2011-05-17 4:48 AM
Thanks, damh,
this solution works for me for all but the WRITE_MEMORY commad. There I get a NACK after sending the data. After some sniffing on the serial port I can confirm that the computed checksum is correct (the same checksum is sent by the FlashLoaderDemonstratorGUI). When the c# library is finished, I will publish it on my Homepage. Carsten- Mark as New
‎2011-05-17 4:48 AM
At which address do you try to write?
First 2 or 4 pages can be written only after mass erase until first reset. After that they are writeprotected.- Mark as New
‎2011-05-17 4:48 AM
For the read
Send 0000 : 11 Send 0000 : EE Receive (ACK) 0000 : 79 ------------------------- Send 0000 : 1F Send 0000 : FF Send 0000 : F0 Send 0000 : 00 Send 0000 : 10 Receive (ACK) 0000 : 79 ------------------------- Send (N) 0000 : 0F Send (N ^ 0xFF) 0000 : F0 Receive (ACK) 0000 : 79 Receive (N + 1) 0000 : 00 02 00 20 21 F0 FF 1F 45 F7 FF 1F 47 F7 FF 1F ------------------------- The address is self contained with it's own XOR sum For Address 0x20000000 the 5 bytes are 20 00 00 00 20 For Address 0x1FFFF000 the 5 bytes are 1F FF F0 00 10 ie 0x1F ^ 0xFF ^ 0xF0 ^ 0x00 = 0x10 This is used for all DWORD parameters The length is sent as N, N ^ 0xFF And it returns 0x79, then N+1 bytes from memoryUp vote any posts that you find helpful, it shows what's working..
