Facing issue in read ADC with GPDMA in STM32U585ZIT6Qwith trust zone option enabled
2023-06-06
10:35 PM
- last edited on
2023-06-27
6:41 AM
by
Laurids_PETERSE
Hi;
I am using STM32U585ZIT6Q controller in my current project. I am enabled Trust Zone option.
I have configured ADC 1 (4 channel) in non secure with GPDMA.I am not able to read ADC data. I have attached all configuration. I have used HCLK(160MHz) for ADC.
if i got working example then it will more helpful.
Please help me for same.
ADC
DMA
STM32U5 series
2023-06-12 7:56 AM - edited 2023-11-20 3:48 AM
Here attached my previous project with ADC1 in non secure context (NS) and in 12bit resolution.
I also added ADC1 channel computation en mV for VREFINT, VBAT and Degree Celsius for TempSensor.
I do not implemented ADC4, it's up to you for its implementation where you want.
As explained before, I just changed ADC1 secure context as following.
- Regenerated the projet
- Move ADC1 user code and callback from \secure\main.c to \Nonsecure\main.c
Good luck.
Romain,
2023-06-06 11:39 PM
Hi @JShah.7 (Community Member)
According Datasheet DS13086 Rev 7 the Table 104. 14-bit ADC1 characteristics indicates the max ADC1 frequency is 55MHz. You must increase ADC clock prescaler input.
Check also you enabled internal VDDA switch before using ADC1 with:
HAL_PWREx_EnableVddA();
Let me know if it helps?
romain,
2023-06-07 12:18 AM
Hi @RomainR.
Thanks for suggestion. As per your suggestion i use HAL_PWREx_EnableVddA(); function and 16MHz(HSI) clock but still result is same.
2023-06-07 12:24 AM
Is it a custom board?
Are you able to have ADC1 conversion working in these conditions:
- Without TZ enable?
- Without GPDMA transfer?
2023-06-07 12:31 AM
Yes,
I have tested with STM32U575ZIT6Q and it is working in both condition. Also it is working with GPDMA. But if i enable TZ it is not working.
2023-06-07 1:03 AM
In your case, TZ security is active. so, ADC Peripheral, SRAM memory for GPDMA transfer and GPIO are either securable or TrustZone-aware.
In this case you must use Global TrustZone controller (GTZC) to configure your application in secure mode.
Refer to AN5347 - Rev 6 chapter 4 and 11.
2023-06-07 3:05 AM
I have configured GTZC but still result is same. Can you please share me example code for ADC with Trustzone enable?
2023-06-07 4:34 AM
Sorry, example your are requesting is actually not available.
But, share your project, I will check your ADC1, GPDMA channel linked-list and GTZC configuration.
regards,
romain,
2023-06-07 10:01 PM
Shared. Please check message.
2023-06-08 5:29 AM - edited 2023-11-20 3:47 AM
Hello @RomainR.
Thanks for your support.
Here I have a query regarding supported peripherals for the secure firmware.
Is secure firmware support ADC or not?
Thanks,
Chintan Patel
