External Interrupt Issue
‎2018-02-19 4:20 AM
We are using stm32f051r4t6 for a new project and the IDE is Keil V5 . We are generating an external interrupt on Pin PC2 . The hardware set up is a push button in pull down arrangement whose interrupt should occur at rising edge , but for us the interrupt occurs at both rising and falling edge . Please help us to solve this issue . The code is as follows ....Any help would be appreciated .
void ext_interruptInit()
{ RCC->AHBENR |= RCC_AHBENR_GPIOCEN; RCC->APB2ENR |= (RCC_APB2ENR_SYSCFGEN); SYSCFG->EXTICR[0] |= (SYSCFG_EXTICR1_EXTI2_PC); EXTI->IMR = 0x0004; EXTI->RTSR = 0x0004; /* EXTI->FTSR = 0x0004; */ NVIC_EnableIRQ(EXTI2_3_IRQn);}void EXTI2_3_IRQHandler(void)
{ GPIOC->MODER |= BIT(20); GPIOC->ODR ^= BIT(10); EXTI->PR |= (EXTI_PR_PIF2);}#stm32f0- Labels:
STM32F0 Series
‎2018-02-19 4:33 AM
How do you know that?
‎2018-02-19 6:13 AM
In short: Key debouncing issue to take care of.
‎2018-02-19 10:29 PM
When push button is in pull down arrangement and pull up arrangement , and when Rising trigger ( EXTI_RTSR) is enabled for input line, the interrupt occurs at both the cases .
‎2018-02-20 1:28 AM
That does not answer the question.
As
Centauris.Alpha
‌ says, how do you know it's not jut contact bounce ?A complex system designed from scratch never works and cannot be patched up to make it work.
