: Error: No STM32 target found!
samuelbs
I designed my board using the STM32L476RGT6. However, when using the ST-Link via SWD, I get the following message:
Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication.
I have checked all connections and voltages, and everything is correct, with the proper 3.3V values.
I am sending the schematic and a photo of the programmer.
Note: I did not solder the VCAP capacitors, and there is no voltage on these pins.
10 REPLIES 10
Thank you very much for the link! I ended up considering the wrong marking...
