: Error: No STM32 target found!
‎2025-02-28 1:51 PM - last edited on ‎2025-03-01 6:32 AM by Andrew Neil
I designed my board using the STM32L476RGT6. However, when using the ST-Link via SWD, I get the following message:
Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication.
I have checked all connections and voltages, and everything is correct, with the proper 3.3V values.
I am sending the schematic and a photo of the programmer.
Note: I did not solder the VCAP capacitors, and there is no voltage on these pins.
- Labels:
STM32L4 series
‎2025-03-05 5:07 AM
>VCAPs are jumpered to GND, as the datasheet states they are VSS.
I dont understand this.
VCAP pins must have no connection to GND. Only 2u2 (or 4u7) cer. capacitors ,
going from vcap.pin---2u2cap.---GND.
And sure: no short to GND on any VCAP.pin ?
‎2025-03-01 2:51 PM
Do you use an ST-LINK debugger?
Have you wired NRST also to debugger header?
The "UR connection mode" seems to mean: debugger wants to connected Under Reset (it wants to force a reset and connect). But if you do not populate NRST to debugger - maybe the reason.
A forum link with similar symptom:
https://community.st.com/t5/stm32cubeprogrammer-mcus/stlink-v2-not-recognizing-stm32cubeprogrammer-ur-connection-mode/td-p/581187
‎2025-03-02 1:26 AM
At first solder the vcap caps. And verify the voltage there, about 1.3 V . This is the CPU core supply - so the most important voltage to check.
‎2025-03-04 4:57 PM
I measured 0V on the VCAP pins and a current consumption of 60mA (STM32L476RGT6 + LC76G), which I consider very high.
I am using the ST-Link from my Nucleo board, and when I reinsert the jumper, the STM32L4 on the Nucleo board works perfectly.
Additionally, I have already checked for possible shorts in the soldering or PCB and found none.
Could this be an issue with the MCU?
‎2025-03-05 1:02 AM
>0V on the VCAP pins
= core has no supply.
So check for any short on VCAP .
If you didnt give 3v3 to vcap or something like that (static discharge) - cpu should be ok.
If you have another board, try it; to compare.
‎2025-03-05 3:43 AM
I checked my Nucleo-L476RG, and the VCAPs are jumpered to GND, as the datasheet states they are VSS. I tried doing the same, but it didn't work. I verified all 3V3 and GND connections, and they are okay.
Even so, the error message appears:
"Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication."
‎2025-03-05 5:07 AM
‎2025-03-05 11:20 AM
I found the error—I accidentally soldered the MCU rotated 360° (I confused the two markings on top of it). I corrected it, and now it works as expected.
Thank you very much for the help! I was able to learn a bit more with you.
‎2025-03-05 12:05 PM
360deg? then it would be the same.
There should be just one pin 1 marking, maybe two other "holes" for pressing the package.
Pin 1 should be on lower left corner and all the text is correct and readable.
This doc. might help next time:
‎2025-03-05 12:36 PM - edited ‎2025-03-05 12:37 PM
Good.
And reality looks like this:
So "a dot" is not the important thing to look for, but the alignment of the font (to read it) - and then to decide, what is the "lower left corner" with the pin1 mark.
