2009-12-01 12:03 AM
ERROR MAKE MENUCONFIG
2011-05-17 4:32 AM
Hi Guys!
I had bouhgt ''STM3210E-EVAL'' board from ST. I were dowloads the original Uclinux source file from the Uclinux project page ... I am building the Uclinux image and with some errors when ''make menuconfig'': ''[host_nguyen@localhost uClinux-dist]$ make menuconfig config/mkconfig > Kconfig CC=cc CXX=c++ make -C /home/host_nguyen/wordspace/uClinux-dist/config/kconfig conf lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found lxdialog/check-lxdialog.sh: line 9: cc: command not found make[1]: Entering directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig' cc -DCURSES_LOC='''' -DKBUILD_NO_NLS -c -o conf.o conf.c /bin/sh: cc: command not found make[1]: *** [conf.o] Error 127 make[1]: Leaving directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig' make: *** [/home/host_nguyen/wordspace/uClinux-dist/config/kconfig/conf] Error 2 '' Can you help me? I don't known ,how i do? Here is my email address:''lehoangnguyen_bd@yahoo.com.vn''. Thanks a lot! Regards Nguyen
